Most recent update: 2022-09-12
金属製品製造のスペシャリストとして、お客様に満足して頂ける製品、加工技術を日々追及
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Company name |
有限会社 小林製作所 (Kobayashiseisakusho) |
Website URL | http://www.ksx.jp/ |
Street address |
Tochigi Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 28 |
Annual sales | 260,000,000 JPY | EMIDAS Member Number | 5516 |
Type of manufacturing | Jigs and tools / Industrial machinery / Telecommunication equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Drawing metal press die designing General metal press die 3D modeling (press) NC data creation (press) |
Designing | Jig and tool designing | General jig designing Mass production jig designing General-purpose jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Keyway milling Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Deburring Coating Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Corner shearing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Sash molding die Compound die |
Mass production | Metal press | Drawing Bending Blanking Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Heat treatment | Quenching Flame quenching |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing Sound blast Glass beads blast |
Assembly/Inspection | Assembly | Precision equipment assembly |
Assembly/Inspection | Repair | Precision equipment repair Die repair |
Parts manufacturing | Machinery part | Gear manufacturing Optical parts manufacturing |
