Most recent update: 2023-12-22
Company name |
札幌ボデー工業 株式会社 (Sapporobode-kougyou) |
Website URL | http://www.sapporo-body.co.jp/ |
Street address |
Hokkaido Japan
[See map] |
Person in charge | - |
Capital | 35,000,000 JPY | Employees | 103 |
Annual sales | Unregister | EMIDAS Member Number | 5402 |
Type of manufacturing | Kitchen / Transportation equipment / Leisure goods |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Gear hobber Thread-cutting Iron Stainless steel Aluminum alloy Machining (resin) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Kitchen unit manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Bending Small-size prototype manufacturing Chassis prototype manufacturing Fused Deposition Molding (FDM) |
Die manufacturing | Plastic mold | Expansion molding die Insert molding die Outsert molding die RTM die |
Die manufacturing | Casting die | Wooden model |
Mass production | Metal press | Bending Blanking Iron Stainless steel Aluminum Plated steel plate Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) |
Mass production | Plastic | Insert molding Outsert molding Expansion molding PMMA (polymethyl methacrylate) FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin FRP molding (hand lay-up/spray lay-up) |
Surface treatment | Other surface treatment | Buffing |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Electrical part | Harness processing |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing |
Product manufacturing | Craftwork/Event and ceremonial goods | Wooden product manufacturing |
