Most recent update: 2023-08-24
Company name |
不二精工株式会社 (Fujiseikou) |
Website URL | http://www.fuji-seiko.com |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 50 |
Annual sales | 1,700,000,000 JPY | EMIDAS Member Number | 53958 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Electronic parts |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) General metal press die NC data creation (press) |
Designing | Electrical planning | Electrical machinery and apparatus designing Other electronic part designing |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Progressive die Single press die Below 60 t |
Die manufacturing | Plastic mold | Designing Injection molding die Insert molding die Outsert molding die |
Mass production | Metal press | Drawing Bending Blanking Forming Coining Iron Stainless steel Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Progressive press (35 - 80 t) |
Mass production | Plastic | Insert molding Outsert molding General-purpose material Engineering plastic PBT (polybutylene terephthalate) LCP (liquid crystal polymer) Injection molding EP (epoxy) |
Assembly/Inspection | Assembly | Precision equipment assembly |
Assembly/Inspection | Inspection | Metal press Plastic |
Parts manufacturing | Spring | Thin leaf spring Terminal spring |
