Most recent update: 2023-02-08
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
有限会社 齋藤製作所 (Saitouseisakusho) |
Website URL | http://www.senbankakou.com/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 5 |
Annual sales | Unregister | EMIDAS Member Number | 53366 |
Type of manufacturing | Machine tools / Industrial machinery / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Copper alloy Titanium alloy Molybdenum alloy Keyway milling Automatic lathe Bench lathe machining Milling (resin) Lathe machining (resin) Casting Honing |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining NC vertical lathe |
Development and production of prototype/Small-scale production | Grinding processing | Cylindrical grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Prototype processing | Aluminum die-casting |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Chemical conversion coating Iron Brass Aluminum Stainless steel Other anti-rust treatments Degreasing Black oxide finish Hard alumite Unichromate (white) Black chromate (black/green) |
Surface treatment | Heat treatment | Normalizing Annealing Quenching Salt bath quenching Vacuum quenching High frequency quenching Carburized quenching Salt bath soft nitriding (tufftriding) |
Surface treatment | Other surface treatment | Buffing Shot blast |
Parts manufacturing | Machinery part | Vacuum components manufacturing Connection parts manufacturing Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
