Most recent update: 2023-09-29
自社内に金型工場・鋳造工場・機械加工工場を持っています。
多品種小ロット生産に対応いたします。
業界一の短納期に対応いたします。
Lost-wax ( Mass production / Casting ) |
Company name |
キングパーツ 株式会社 (Kinngupa-tsu) |
Website URL | https://www.kingparts.co.jp/ |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | 140,000,000 JPY | Employees | 326 |
Annual sales | 4,394,300,000 JPY | EMIDAS Member Number | 5321 |
Type of manufacturing | Heavy electric machinery / Machine tools / Industrial machinery |
Large | Medium | Small |
Designing | Mold designing | Casting die designing |
Designing | Simulation | Casting |
Designing | Data creation (3D scan) | 3D printer |
Development and production of prototype/Small-scale production | Machining | Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Five-face machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Rotary grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Development and production of prototype/Small-scale production | Casting | Lost wax Cast steel Aluminum alloy Copper alloy Aluminum bronze 500g or less 500g-5kg 5kg or more |
Die manufacturing | Casting die | Lost-wax casting die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Gear cutting machining Screw cutting machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Nickel alloy Broaching machining Automatic screw machining Casting Honing machining High precision |
Mass production | Casting | Lost-wax Cast steel Aluminum alloy Copper alloy Over 500 g and less than 5 kg 5 kg and over Aluminum bronze alloy |
Surface treatment | Plating/Chemical conversion treatment | Nickel (rack) Chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (rack) Chemical conversion coating Baking (hydrogen embrittling) Iron Copper Aluminum Stainless steel Other anti-rust treatments Hard chromium (rack) Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Cleaning | Ultrasonic cleaning |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Buffing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Vacuum quenching High frequency quenching Solution heat treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Teflon coating Shot blast Sound blast Glass beads blast Etching (surface treatment) Deburring |
Assembly/Inspection | Inspection | Casting |
Parts manufacturing | Machinery part | Valve manufacturing Bearing manufacturing Connection parts manufacturing Optical parts manufacturing Measurement devices manufacturing Mechanical parts |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Lubrication equipment manufacturing Optical products manufacturing Hydraulic pressure equipment manufacturing Food industry machinery manufacturing Fluid equipment manufacturing Industrial robot manufacturing Semiconductor manufacturing equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Hydro/thermal/electric/atomic power generation apparatus manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Combustor manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing Surgical instruments Inspection and testing devices |
Product manufacturing | Food industry machinery manufacturing | Energy-saving fishery machinery manufacturing Other food industry machinery manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing |
