信号機スイッチボックス
Nitrogen cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Thick plate (over 6 mm)( Development and production of prototype/Small-scale production / Blank cutting ) |
Stainless steel( Development and production of prototype/Small-scale production / Blank cutting ) |
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Chassis prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Hair line machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
CO2 laser machining ( Development and production of prototype/Small-scale production / Blank cutting ) |
Thickness: over 9.0 mm( Mass production / Metal press ) |
| Company name |
株式会社 ワールド山内 (Wa-rudoyamauchi) |
Website | www.world-yamauchi.co.jp/ |
| Street address |
Hokkaido Japan
[See map] |
Person in charge | - |
| Capital | 30,000,000 JPY | Employees | 100 |
| Annual sales | 1,200,000,000 JPY | EMIDAS Member Number | 5234 |
| Large | Medium | Small |
| Development and production of prototype/Small-scale production | Machining | Copper alloy Aluminum alloy Stainless steel Iron Tapping |
| Development and production of prototype/Small-scale production | Sheet-metal processing | Bending (hydraulic) Thin wall (Thickness 3-roll bending Mirror surface machining Coating Deburring Pipe bending Angle machining Bending (over 3.0 m) Sheet metal protocol manufacturing Precision sheet metal machining Pipe machining Can manufacturing Hair line machining 3-roll bending (2 m or longer) Chassis manufacturing |
| Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Corner shearing Shearing (longer than 121.2 m) Laser processing (longer than 121.2 m) Cutting Shearing Acrylic Copper/Aluminum Thin plate (below 6 mm) Microfabrication (laser machining ) Laser marking Nitrogen cutting Thick plate (over 6 mm) Stainless steel Laser and turret punch press processing CO2 laser machining |
| Development and production of prototype/Small-scale production | Prototype processing | Bending Welding Small-size prototype manufacturing Chassis prototype manufacturing |
| Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Stud welding Robot welding Arc welding Seam welding TIG welding (argon welding) Spot welding CO2 welding |
| Mass production | Metal press | Thickness Thickness Thickness Stainless steel material for spring Plated steel plate Phosphor bronze Brass Stainless steel Iron Bending Thickness Copper Aluminum |
| Mass production | Plastic | PMMA (polymethyl methacrylate) |
| Surface treatment | Plating/Chemical conversion treatment | Acid pickling |
| Surface treatment | Coating | Air-spray coating Metal coating Acrylic coating Urethane coating Melamine coating |
| Surface treatment | Other surface treatment | Buffing Sound blast Glass beads blast Shot blast |
| Assembly/Inspection | Assembly | Construction component assembly |
