Most recent update: 2023-12-22
Company name |
有限会社 サンアイ精機 (Sannaiseiki) |
Website URL | http://www.rnac.ne.jp/~sanaisk/html/jp/ |
Street address |
Iwate Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 10 |
Annual sales | Unregister | EMIDAS Member Number | 5202 |
Type of manufacturing | Machine tools |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel High rigid material Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding Profile grinding Jig grinding Internal grinding |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Die manufacturing | Press die | Manufacturing Part processing |
Mass production | Casting | Sand casting Cast-iron Ductile cast iron Aluminum alloy Zinc alloy |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Alumite (anode oxidation) Electroless nickel (barrel) |
Surface treatment | Heat treatment | Annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum quenching Austempering High frequency quenching Flame quenching Sub-zero treatment Carburized quenching |
