Most recent update: 2022-11-17
「お客様の期待を超える製品とサービスを提供する」を会社方針として日々活動しています。
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
有限会社 三光製作所 (Sannkouseisakusho) |
Website URL | http://www.sankou-ss.co.jp/ |
Street address |
Gunma Japan
[See map] |
Person in charge | - |
Capital | 35,000,000 JPY | Employees | 28 |
Annual sales | 330,000,000 JPY | EMIDAS Member Number | 51965 |
Type of manufacturing | Industrial machinery / Home electrical appliances / Office appliances |
Large | Medium | Small |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Deburring 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Metal press | Bending Blanking Iron Stainless steel Aluminum Copper general purpose plating Painting Degreasing welding Tap processing Single press (below 80 t) barrel Single press (80 - 200 t) |
Mass production | Sheet-metal processing | NC set press Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Deburring process 3-roll machine Bender processing (flood control) Bender processing (servo) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) Stud welding |
Surface treatment | Plating/Chemical conversion treatment | Iron Aluminum Stainless steel Hot-dip galvanizing (small-size Hot-dip galvanizing (mid-size |
Surface treatment | Coating | Powder coating Electrodeposition coating Metal coating |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Assembly/Inspection | Inspection | Metal press |
