Most recent update: 2022-11-10
Company name |
株式会社 菊池製作所 (Kikuchiseisakusho) |
Website URL | http://www.kikuchiseisakusho.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 170,000,000 JPY | Employees | 441 |
Annual sales | 6,000,000,000 JPY | EMIDAS Member Number | 50595 |
Type of manufacturing | Office automation equipment / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) General metal press die 3D modeling (press) 3D modeling (plastic) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting CO2 laser machining |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Bending Small-size prototype manufacturing Vacuum injection molding |
Die manufacturing | Press die | Designing Manufacturing Part processing NC data creation 3D modeling Drawing die Bending die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining 3D modeling Injection molding die |
Mass production | Metal press | Drawing Bending Forming Shaving Transfer press (below 80 t) Thickness Diameter Single press (below 80 t) Progressive press (35 - 80 t) |
Mass production | Plastic | Vacuum molding Insert molding Below 60 t Injection molding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Copper (barrel) Chromium (barrel) Nickel (rack) Gold/Silver plating Alumite (anode oxidation) Electroless nickel (barrel) |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Parts manufacturing | Spring | Thin leaf spring Compression coil spring Tensil coil spring Leaf spring Shaped spring |
