Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Part processing( Die manufacturing / Plastic mold ) |
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
Plate machining( Die manufacturing / Press die ) |
Iron( Surface treatment / Plating/Chemical conversion treatment ) |
Aluminum( Surface treatment / Plating/Chemical conversion treatment ) |
Company name | Sineiseiki YK | Website URL | |
Street address |
Higashi-Osaka Osaka Japan
[See map] |
Person in charge | 島田 英季 |
Telephone number | +81-72-968-7761 | Fax number | +81-72-968-7829 |
Capital | 3,000,000 JPY | Employees | 28 |
Annual sales | 330,000,000 JPY | EMIDAS Member Number | 49689 |
Type of manufacturing | Jigs and tools / Machine tools / Industrial machinery | ||
Main 3 products |
Primary clients |
PR message
Mainly metal processing (stainless steel, aluminum, iron and other metals) with milling, machining and plate processing machines
We undertake precision cutting.
We've made numerous achievements with machining in general for machining equipment parts such as industrial machine parts, mold components, semiconductor equipment parts and jigs. In particular, we take rush orders for production at our machining center.
We are working to improve our operations day by day to answer customers' quality, cost and quick delivery needs.
We handle various kinds of material qualities including all types of iron, aluminum, stainless steel, casting and resins.
Most recent update:2024-04-25
Large | Medium | Small |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Precision automatic machinery designing Industrial machinery designing |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Deep hole drilling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Machining (resin) Keyway milling Automatic lathe Milling (resin) Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Cylindrical grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Aluminum die-casting |
Die manufacturing | Press die | Part processing Plate machining Die set machining |
Die manufacturing | Plastic mold | Part processing Plate machining Mold base machining |
Mass production | Mechanical processing | Machining NC milling machining Tapping machining Wire machining Iron Stainless Cemented carbide Aluminum alloy Turning machining(plastic) Casting |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Zinc (rack) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Iron Brass Aluminum Hard chromium (rack) Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) |
Surface treatment | Polishing/Lapping | Tool polishing Buffing |
Surface treatment | Lap polishing | Lap polishing |
Surface treatment | Heat treatment | Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Vacuum annealing Quenching Vacuum quenching High frequency quenching Sub-zero treatment Carburized quenching Nitridation |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Vacuum components manufacturing |
