We are a Japanese producer of high quality metallic filters and strainers. We can help design custom filters that meet your projects exact needs. We can also mass produce filters at a low cost.
PR message
Our mission is to produce the world's top performance metallic filters.
We manufacture and sell mesh filters and strainers.
Our Processes: Pressing, Welding(Spot, Seam)、Plastic Insert Molding, and more
We can do anything from prototyping to mass production. We have overseas factories in China and Thailand, so overseas manufacturing is possible. Thanks to our integrated production system, we can design molds.
Used in water heaters, car engine oil filters, etc.
Customizable
Can be created in various shapes and sizes
Dispensers for hydrogen station etc.
Customizable
By using sintered metal fiber mesh, it has a high porosity with an excellent filtering accuracy rate of over 2μm. It can also be used at a pressure of over 75MPA. Its heat and corrosion resistance is outstanding
Used in Water supply rectifiers, Solenoid valves, Pneumatic pressure machines etc.
3.2㎜~
We manufacture according to the customer’s request such as producing with flattened edges or using the blank and draw process.
Customizable
Can use two different kinds of mesh at once
For interior compressor filters
6.4~32.0(L)×4.0~30.0(H)mm Customizable
Smallest size: outer dia. 4.75mm (prototype)
We manufacture various shapes, such as caulking type and welding type.
Customizable. Two meshes can be used as reinforcement material.
Compressor interior gas-liquid separation filter, etc.
Customization Possible.
Design and number of holes can be customized.
Separates liquids from gas during the refrigerant cycle.
For gas-liquid separation, vibration reduction and the soundproofing of the interior of air conditioners.
18.1(φ)dia. ×10(H)mm
The circular knitted mesh is compressed. Then the ring is then fitted.
Production without ring fitting and size change is also possible.
Filter manufacturing( Parts manufacturing / Other parts ) |
Company name | Vantech Co., Ltd. | Website URL | https://vthfilter.com/ |
Street address |
Sano-shi Tochigi Japan
[See map] |
Person in charge | Greely Ethan |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 10,000,000 JPY | Employees | 65 |
Annual sales | 772,000,000 JPY | EMIDAS Member Number | 49572 |
Type of manufacturing | Industrial machinery / Home electrical appliances / Electrical component for transportation equipment | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) Drawing metal press die designing General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing |
Development and production of prototype/Small-scale production | Machining | Tapping Iron Stainless steel Copper alloy Sintered metal |
Development and production of prototype/Small-scale production | NC machining | NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining 3-roll bending 3D pipe machining |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Seam welding Arc welding Brazing High-frequency welding Capacitator spot welding Ultrasonic welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Drawing die Bending die Blanking die Progressive die Single press die Press robot die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Powder metallurgy mold | Manufacturing |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Trivalent Chromate (barrel plating) Unichromate (white) |
Assembly/Inspection | Assembly | Auto parts assembly |
Parts manufacturing | Other parts | Filter manufacturing Metallic mesh manufacturing |
