Most recent update: 2024-04-22
Coating( Surface treatment / Other surface treatment ) |
Screw manufacturing( Parts manufacturing / Bolt/Screw/Nut ) |
Nut manufacturing( Parts manufacturing / Bolt/Screw/Nut ) |
Company name |
株式会社 小山 (Koyama) |
Website URL | https://www.koyamas.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 98 |
Annual sales | 5,500,000,000 JPY | EMIDAS Member Number | 49386 |
Type of manufacturing | Office automation equipment / Home electrical appliances / Medical equipment |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Designing | Industrial equipment designing | Energy-saving machinery designing |
Mass production | Metal press | Iron Stainless steel Aluminum Copper Brass Phosphor bronze |
Mass production | Forging | Header machining Cold forging Press forging Iron Aluminum Brass |
Mass production | Casting | Lost-wax Sand casting Magnesium alloy |
Surface treatment | Other surface treatment | Coating Teflon coating |
Parts manufacturing | Machinery part | Gear manufacturing Bearing manufacturing Crank shaft manufacturing Shaft and roller manufacturing |
Parts manufacturing | Spring | Thin leaf spring Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Battery spring Conical spring Formed wire spring Spring washer |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
