株式会社ホシモトは、制御盤,キュービクル,配電盤,分電盤等のキャビネット用ハンドル,ロック,蝶番,取手,銅ブスバー 及び プレス,切削,亜鉛ダイカスト加工品を製造販売するメーカーです。
Zinc( Mass production / Die-casting ) |
125 t or less( Mass production / Die-casting ) |
125 - 250 t( Mass production / Die-casting ) |
500 g and below( Mass production / Casting ) |
NC turning machining( Mass production / Mechanical processing ) |
Machining( Mass production / Mechanical processing ) |
Transfer press (below 80 t)( Mass production / Metal press ) |
Bending process( Mass production / Sheet-metal processing ) |
Iron( Mass production / Mechanical processing ) |
Thickness: 0.2 mm - 3.2mm( Mass production / Metal press ) |
Company name |
株式会社 ホシモト (Hoshimoto) |
Website URL | https://www.hoshimoto.co.jp/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 120 |
Annual sales | Unregister | EMIDAS Member Number | 49373 |
Type of manufacturing | Heavy electric machinery / Jigs and tools / Industrial machinery |
Large | Medium | Small |
Designing | Mold designing | Casting die designing |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Designing | Simulation | Casting |
Designing | Data creation (3D scan) | 3D printer |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Thread-cutting Profile milling Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Nickel alloy Automatic lathe Bench lathe machining Simultaneous 5-axis machining Casting pipe manufacturing Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Sheet metal protocol manufacturing Bending (over 3.0 m) Deburring Mirror surface machining Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Casting | die-cast Lost wax Low pressure casting Metal injection molding (MIM) Zinc alloy 500g or less |
Die manufacturing | Casting die | Designing Manufacturing Die-casting part processing NC data creation 3D modeling Die-casting die |
Mass production | Metal press | Drawing Bending Blanking Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Thickness Thickness Transfer press (80 - 200 t) general purpose plating Painting welding Tap processing crimp Single press (below 80 t) barrel Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Rolling machining Screw cutting machining Electrical discharge machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Automatic screw machining Casting High precision |
Mass production | Die-casting | 125 t or less 125 - 250 t Zinc |
Mass production | Forging | Header machining Cold forging Iron Others Below 500 g |
Mass production | Casting | Lost-wax Low-pressure casting Zinc alloy 500 g and below Over 500 g and less than 5 kg Metal injection molding (MIM) |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Centerless grinding Thread grinding NC internal grinding |
Mass production | Sheet-metal processing | Pipe processing NC set press Sheet metal prototype manufacturing Pipe bender processing Deburring process Mirror surface material processing Hairline processing Bender processing (flood control) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) fixing with wax Stud welding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Copper (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Tin (rack) Copper (rack) Chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Parkerizing (phosphate film) Tin-zinc alloy plating (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Hard chromium (rack) Degreasing Black oxide finish Hot-dip galvanizing (small-size Dacrotizing Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) Hard chrome (barrel) |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrodeposition coating UV resistant coating Acrylic coating |
Surface treatment | Heat treatment | Normalizing Annealing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Sound blast |
Assembly/Inspection | Assembly | Construction component assembly |
Parts manufacturing | Machinery part | Connection parts manufacturing Mechanical parts |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Spring | Leaf spring Conical spring Spring washer Stainless steel |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Parts manufacturing | Other parts | Lock manufacturing |
