Most recent update: 2009-03-26
NC plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Company name |
アンデス電気 株式会社 加工センター (Anndesudennkikabushikikaisha) |
Website URL | http://www.andes.co.jp |
Street address |
Aomori Japan
[See map] |
Person in charge | - |
Capital | 128,670,000 JPY | Employees | 28 |
Annual sales | Unregister | EMIDAS Member Number | 49319 |
Type of manufacturing | Electronic parts / Industrial machinery / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) General metal press die NC data creation (press) |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Precision automatic machinery designing Industrial machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Machining (resin) Keyway milling Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Deburring Coating Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Nickel (rack) Chromium (rack) Alumite (anode oxidation) Electroless nickel (rack) |
Surface treatment | Coating | Air-spray coating Resin coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Printing and others | NC engraving Engraving Silk screen printing |
Surface treatment | Heat treatment | Annealing Quenching Air quenching Salt bath quenching Vacuum quenching High frequency quenching Sub-zero treatment Salt bath soft nitriding (tufftriding) Nitridation |
Surface treatment | Other surface treatment | Sound blast |
