1963年にフッ素樹脂コーティングを開始。1968年には米国デュポン社とライセンス契約を締結。60年以上にわたってテフロンコーティング及び機能性コーティングの加工メーカーとして業界をリードしています。
Teflon coating( Surface treatment / Other surface treatment ) |
Coating( Surface treatment / Other surface treatment ) |
Resin coating( Surface treatment / Coating ) |
Dry type lubricant coating( Surface treatment / Other surface treatment ) |
Heat-resistant coating( Surface treatment / Coating ) |
Electrical insulating( Surface treatment / Coating ) |
Nondestructive test( Designing / Test ) |
Company name |
株式会社 吉田SKT (Yoshidaesukeithi-) |
Website URL | https://www.y-skt.co.jp?utm_source=nc-net.or.jp&utm_medium=referral |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 50,000,000 JPY | Employees | 170 |
Annual sales | Unregister | EMIDAS Member Number | 49279 |
Type of manufacturing | Jigs and tools / Industrial machinery / Electronic parts |
Large | Medium | Small |
Designing | Test | Specimen processing Destructive test Nondestructive test Chemical analysis Investigative research |
Surface treatment | Plating/Chemical conversion treatment | Iron Copper Brass Aluminum Stainless steel Plastic Titanium |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrostatic coating Aqueous coating Urethane coating Epoxy coating Electrical insulating Heat-resistant coating Fluorine coating |
Surface treatment | Other surface treatment | Vacuum deposition Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Coating Teflon coating Shot peening/WPC Shot blast Sound blast Ionized plating Frame spraying Arc spray Plasma spray Dry type lubricant coating DLC coating |
