Most recent update: 2008-05-14
Company name |
有限会社 紺本鉄工所 (Konnmototekkousho) |
Website URL | |
Street address |
Tottori Japan
[See map] |
Person in charge | - |
Capital | 4,300,000 JPY | Employees | 5 |
Annual sales | Unregister | EMIDAS Member Number | 49252 |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Designing | Industrial equipment designing | Carrier machine designing Industrial machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) Broaching Keyway milling Automatic lathe Milling (resin) Lathe machining (resin) Casting Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Pipe bending Coating 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Shearing (longer than 121.2 m) Corner shearing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Chassis prototype manufacturing |
Assembly/Inspection | Assembly | Precision equipment assembly Construction component assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Shaft and roller manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing |
