Most recent update: 2023-10-19
Company name |
株式会社 タケダ (Takeda) |
Website URL | https://www.takeda-co.com/ |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 48,000,000 JPY | Employees | 150 |
Annual sales | 4,000,000,000 JPY | EMIDAS Member Number | 49217 |
Type of manufacturing | Electronic parts / Construction material / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die 3D modeling (press) |
Designing | Product and part designing | Gear designing Office equipment designing |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Designing | Simulation | 3D modeling Forging Press |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | Iron Stainless steel Aluminum alloy Copper alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Laser processing (longer than 121.2 m) CO2 laser machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Forming die Fine blanking die Shaving die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t Over 300 t Compound die |
Die manufacturing | Forging die | Cold forging die |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Coining Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Thickness Bulge forming die Combined press-joining Transfer press (80 - 200 t) Transfer press (200 - 500 t) Transfer press (over 500 t) Press robot (below 80 t) Press robot (80 -200 t) Press robot (200 - 500 t) Press robot (over 500 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Single press (500 t and over) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) Progressive press (over 500 t) |
Mass production | Forging | Cold forging Press forging Iron Brass Below 500 g 500 g - 5 kg Over 5 kg High-strength brass |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press Forging Measuring |
Parts manufacturing | Machinery part | Gear manufacturing Bearing manufacturing |
Parts manufacturing | Spring | Thin leaf spring |
Auto parts manufacturing | Drive system part | Accelerator Clutch Transmission Steering device Drive shaft Caliper Brake parts |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
