Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Chassis manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Tapping machining( Mass production / Mechanical processing ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Iron( Mass production / Metal press ) |
Chromate (general)( Surface treatment / Plating/Chemical conversion treatment ) |
Coating( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
精密板金加工業 株式会社 ナカジ (Nakaji) |
Website URL | |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 26 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 49141 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Deburring Coating Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Die manufacturing | Press die | Die set machining Bending die Blanking die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Thickness |
Mass production | Mechanical processing | Tapping machining Iron Stainless |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Copper (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Zinc (rack) Alumite (anode oxidation) Acid pickling Chemical conversion coating Iron Aluminum Stainless steel |
Surface treatment | Coating | Air-spray coating Electrodeposition coating |
Surface treatment | Printing and others | Printing Silk screen printing |
Assembly/Inspection | Assembly | Precision equipment assembly |
