Most recent update: 2004-02-23
Company name |
株式会社 アロン社 (Aronnsha) |
Website URL | http://www.alone.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 50,000,000 JPY | Employees | 130 |
Annual sales | 2,400,000,000 JPY | EMIDAS Member Number | 48869 |
Type of manufacturing | Electronic parts / Office automation equipment / Telecommunication equipment |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) Stainless steel Copper alloy Nickel alloy |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining CO2 laser machining Etching Microfabrication (laser machining ) Metal mask manufacturing Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Seam welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Mass production | Metal press | Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Stainless steel material for spring Nickel Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Copper (barrel) Chromium (barrel) Black chromium (barrel) Chromate (general) Electroless copper (barrel) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Electrocasting Chemical conversion coating Black oxide finish |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing |
Surface treatment | Printing and others | Engraving |
Surface treatment | Other surface treatment | Vacuum deposition Spattering Coating Resin impregnation Teflon coating Etching (surface treatment) |
Parts manufacturing | Machinery part | Gear manufacturing Vacuum components manufacturing Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Electric board and electronic part | Rigid board Protocol and small-scale (PCB) Flexible board manufacturing Handles one side Handles both sides Handles mass production Fine pattern board |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Leaf spring Conical spring Spring washer Stainless steel Copper alloy |
