昭和32年の創業より、航空機の板金加工を手掛ける、試作板金、精密板金加工の総合メーカーです。レーザー加工機、タレパン加工機、ブレーキプレスなどを多用し、単純な品から複雑な形状まで幅広く受注しています。
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Stainless steel( Mass production / Metal press ) |
Aluminum( Mass production / Metal press ) |
Iron( Mass production / Metal press ) |
Hair line machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Company name |
スエナミ工業 株式会社 (Suenamikougyou) |
Website URL | http://www.suenami.co.jp |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 23 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 48755 |
Type of manufacturing | Industrial machinery / Transportation equipment / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing NC set press Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Hair line machining Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Corner shearing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding |
Mass production | Metal press | Bending Blanking Iron Stainless steel Aluminum Copper Brass Titanium Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Single press (below 80 t) |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Acid pickling Electroless nickel (rack) Iron Black oxide finish Hot-dip galvanizing (small-size Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Powder coating Electrodeposition coating Electrostatic coating Urethane coating Epoxy coating Metal coating |
