Most recent update: 2012-06-13
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
大瀬工業 株式会社 (Oosekougyou) |
Website URL | http://www.ohsekogyo.co.jp/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 45,000,000 JPY | Employees | 75 |
Annual sales | 1,100,000,000 JPY | EMIDAS Member Number | 48693 |
Type of manufacturing | Industrial machinery / Transportation equipment / Furniture |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Broaching Keyway milling |
Development and production of prototype/Small-scale production | NC machining | NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Sheet metal protocol manufacturing Pipe bending Coating 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Seam welding Arc welding Robot welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Drawing die Bending die Blanking die Progressive die Single press die 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Plated steel plate Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) |
Surface treatment | Coating | Electrodeposition coating |
Assembly/Inspection | Assembly | Office equipment assembly Auto parts assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press |
