Most recent update: 2022-06-22
Company name |
東都発条 株式会社 (Toutohatsujou) |
Website URL | http://www.tohtospring.co.jp/ |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 48,000,000 JPY | Employees | 140 |
Annual sales | 2,400,000,000 JPY | EMIDAS Member Number | 48595 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Leaf spring die |
Mass production | Metal press | Bending Blanking Forming Multi forming Iron Stainless steel Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter |
Surface treatment | Heat treatment | Annealing Air quenching |
Parts manufacturing | Spring | Terminal spring Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring Battery spring Conical spring Formed wire spring Spring washer Torsion spring Carbon steel Piano wire (carbon wire) Stainless steel Diameter Diameter Diameter |
