Most recent update: 2022-11-14
Mirror surface machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
日本プレート精工 株式会社 (Nihonnpure-toseikou) |
Website URL | http://nps1.jp |
Street address |
Shiga Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 16 |
Annual sales | Unregister | EMIDAS Member Number | 47223 |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Designing | Industrial equipment designing | Carrier machine designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Nickel alloy Keyway milling Automatic lathe Handles microfabrication Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing Microfabrication (laser machining ) Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending Small-size prototype manufacturing |
Surface treatment | Polishing/Lapping | Electropolishing Mirror polishing |
Surface treatment | Other surface treatment | Buffing Sound blast |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
