Most recent update: 2022-01-25
Company name |
株式会社 岡本金型製作所 (Okamotokanagataseisakusho) |
Website URL | |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 7 |
Annual sales | Unregister | EMIDAS Member Number | 47214 |
Type of manufacturing | Home electrical appliances / Leisure goods / Construction material |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Drawing metal press die designing Transfer press die designing General metal press die NC data creation (press) |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Planer machining Plano miller machining Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Machining (resin) |
Development and production of prototype/Small-scale production | NC machining | NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Jig grinding Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Sash molding die |
Mass production | Metal press | Drawing Bending Blanking Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Diameter Diameter Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) |
Surface treatment | Printing and others | Engraving |
Surface treatment | Heat treatment | Annealing Full annealing Vacuum annealing Quenching Vacuum quenching High frequency quenching Gas nitrocarburizing |
Assembly/Inspection | Repair | Construction repair Die repair |
