Most recent update: 2014-02-10
Company name |
株式会社 サトウプロダクト (Satoupurodakuto) |
Website URL | http://www.satopro.co.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 23,000,000 JPY | Employees | 100 |
Annual sales | 2,400,000,000 JPY | EMIDAS Member Number | 47066 |
Type of manufacturing | Industrial machinery / Jigs and tools / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Drawing metal press die designing General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Rolling Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Pipe bending Coating Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Shearing (longer than 121.2 m) Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Drawing die Bending die Blanking die Forming die Progressive die Single press die 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Forming Thickness Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Chromium (barrel) Zinc (barrel) Chromate (general) Alumite (anode oxidation) Acid pickling Parkerizing (phosphate film) |
Surface treatment | Coating | Powder coating Electrodeposition coating Electrostatic coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Heat treatment | Normalizing Annealing Quenching |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing Shot blast |
