Most recent update: 2018-07-10
General jig designing( Designing / Jig and tool designing ) |
Company name |
株式会社 トラスト (Torasuto) |
Website URL | http://www.trust.gr.jp |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 11 |
Annual sales | 400,000,000 JPY | EMIDAS Member Number | 46938 |
Type of manufacturing | Jigs and tools / Industrial machinery / Home electrical appliances |
Large | Medium | Small |
Designing | Mold designing | Drawing metal press die designing General metal press die NC data creation (press) |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Rolling Thread-cutting Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Molybdenum alloy Ceramic Machining (resin) Broaching Keyway milling Automatic lathe Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Urethane Sponge Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Sheet metal protocol manufacturing Pipe bending Deburring Coating Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding Profile grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Small-size prototype manufacturing Vacuum injection molding Fused Deposition Molding (FDM) |
Die manufacturing | Press die | Designing Manufacturing Part processing NC data creation Drawing die Bending die Blanking die Progressive die Single press die |
Die manufacturing | Forging die | Manufacturing |
Die manufacturing | Casting die | Manufacturing |
Mass production | Metal press | Drawing Bending Blanking Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) |
Mass production | Plastic | Blow molding Vacuum molding Insert molding Expansion molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic Urethane resin PU (polyurethane) Injection molding |
Surface treatment | Printing and others | NC engraving Engraving |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
