Most recent update: 2012-02-01
Recommended (best match) |
Website |
Icon |
Company info
| Company name |
株式会社 三協製作所 (Sannkyouseisakusho) |
EMIDAS Member Number | 46820 |
| Country | Japan | Street address |
Osaka |
| Type of manufacturing | Home electrical appliances / Construction material / Lighting equipment | Capital | 10,000,000 JPY |
| Annual sales | 400,000,000 JPY | Employees | 35 |
Manufacturing category info
General metal press die( Designing / Mold designing ) |
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Industrial machinery assembly( Assembly/Inspection / Assembly ) |
| Large | Medium | Small |
| Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
| Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing Transfer press die designing NC data creation (press) General metal press die |
| Material | Steel component distribution | Pickled steel plate Heavy plate Stainless steel Stainless steel spring Hot-rolled steel plate Cold-rolled steel plate Electroplated steel plate Hot-dipped steel plate Colored steel plate Tin Spring steel Other steel plates and straps Flat steel plate Perforated metal Expanded metal |
| Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping |
| Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
| Development and production of prototype/Small-scale production | Sheet-metal processing | Bending (hydraulic) Pipe machining Sheet metal protocol manufacturing Deburring Coating |
| Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing |
| Development and production of prototype/Small-scale production | Grinding processing | Thread grinding |
| Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
| Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
| Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Seam welding Arc welding Robot welding Stud welding |
| Die manufacturing | Press die | Designing Manufacturing Part processing Die set machining NC data creation Drawing die Bending die Blanking die Shaving die Progressive die Transfer press die Single press die Press robot die Sash molding die Compound die Below 60 t 60 - 300 t |
| Mass production | Metal press | Combined press-joining Transfer press (80 - 200 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Press robot (80 -200 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Drawing Bending Blanking Progressive press (80 - 200 t) |
| Assembly/Inspection | Assembly | Construction component assembly Industrial machinery assembly |
| Assembly/Inspection | Inspection | Metal press Measuring |
| Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
Sannkyouseisakusho (株式会社 三協製作所)
