Most recent update: 2022-12-23
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
有限会社 英照明 (Hanabusashoumei) |
Website URL | http://www.e-hanabusa.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 6 |
Annual sales | Unregister | EMIDAS Member Number | 46389 |
Type of manufacturing | Industrial machinery / Medical equipment / Lighting equipment |
Large | Medium | Small |
Designing | Product and part designing | External design |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding Capacitator spot welding YAG laser machining Fiber welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Aluminum die-casting |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Thickness Single press (below 80 t) |
Mass production | Sheet-metal processing | Pipe processing Can-making Air conditioning equipment manufacturing Kitchen equipment manufacturing NC set press Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Angle processing Deburring process Mirror surface material processing Hairline processing 3-roll machine Bender processing (flood control) Bender processing (servo) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | YAG laser processing Turret punch punching Shirring Cutting process Laser and turret punch punching Connor Shah CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Precision cutting |
Mass production | Welding / welding | CO2 welding Fiber welding Spot welding TIG welding (argon welding) Arc welding fixing with wax Stud welding Condenser spot welding YAG laser processing |
Surface treatment | Polishing/Lapping | Buffing |
Product manufacturing | Production property | Electrical machinery and apparatus manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
