Most recent update: 2023-06-02
Company name |
株式会社 カトメ (Katome) |
Website URL | https://www.kato-s.co.jp/ |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 58 |
Annual sales | 800,000,000 JPY | EMIDAS Member Number | 46375 |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Iron Stainless steel Aluminum alloy Copper alloy Sintered metal Keyway milling Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Jig grinding |
Die manufacturing | Casting die | Designing Manufacturing Die-casting part processing Lost-wax casting die |
Mass production | Casting | Lost-wax Gravity casting Cast steel 500 g and below Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Nickel (rack) Chromium (rack) Zinc (rack) Nickel chromium (rack) Acid pickling |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Heat treatment | Normalizing Annealing Quenching High frequency quenching Solution heat treatment Carburized quenching |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast |
