Most recent update: 2023-04-04
Thin wall (Thickness: 0.5 or less)/small-size sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Company name |
有限会社 小林製作所 (Kobayashiseisakusho) |
Website URL | http://www.ops.dti.ne.jp/~bb2000/index.htm |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 10 |
Annual sales | Unregister | EMIDAS Member Number | 46241 |
Type of manufacturing | Industrial machinery / Electronic parts / Medical equipment |
Large | Medium | Small |
Designing | Product and part designing | Pressure container designing |
Designing | Industrial equipment designing | Food industry machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Nickel alloy Bench lathe machining Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Pipe bending Deburring Coating Mirror surface machining 3-roll bending Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Electron beam machining Laser processing (longer than 121.2 m) CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Stainless steel Acrylic |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Seam welding Brazing Capacitator spot welding YAG laser machining |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Parts manufacturing | Other parts | Sign board manufacturing Filter manufacturing Metallic mesh manufacturing Blade manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Measurement/testing devices manufacturing Food industry machinery manufacturing Fluid equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
