Most recent update: 2001-11-30
Company name |
株式会社 勇心スプリング (Yuushinnsupurinngu) |
Website URL | http://www.yushin-sp.co.jp/ |
Street address |
Chiba Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 40 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 45907 |
Type of manufacturing | Jigs and tools / Office automation equipment / Telecommunication equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Drawing metal press die designing General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Electron beam machining CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Seam welding Arc welding Robot welding Brazing Brazing Plastic bonding Stud welding Submerged arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Wire spring die Leaf spring die |
Surface treatment | Lap polishing | Lap polishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Shot peening/WPC Shot blast Sound blast Water blast Glass beads blast |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Spring | Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring Battery spring Conical spring Formed wire spring Volute spring Spring washer Torsion spring Carbon steel Piano wire (carbon wire) Stainless steel Copper alloy Diameter Diameter Diameter |
