Most recent update: 2008-05-09
FRP molding (CFRP, auto-clave)( Mass production / Plastic ) |
Company name |
株式会社 UCHIDA (Kabushikigaisha uchida) |
Website URL | http://www.uchida-k.co.jp |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 50,000,000 JPY | Employees | 40 |
Annual sales | Unregister | EMIDAS Member Number | 45842 |
Large | Medium | Small |
Designing | Mold designing | 3D modeling (press) 3D modeling (plastic) |
Designing | Product and part designing | Model designing |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Test | Specimen processing Destructive test Nondestructive test Investigative research |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | Iron Stainless steel Aluminum alloy Magnesium alloy Titanium alloy Machining (resin) Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Grinding processing | Jig grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Photoforming Small-size prototype manufacturing Vacuum injection molding Model manufacturing |
Mass production | Plastic | Vacuum molding PMMA (polymethyl methacrylate) PI (polyimide) PEEK (polyetheretherketone) Thermoset resin FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin FRP molding (hand lay-up/spray lay-up) EP (epoxy) CFRP (carbon fiber reinforced plastic) auto-clave) SMC) |
Surface treatment | Plating/Chemical conversion treatment | Plastic |
Surface treatment | Coating | Air-spray coating Resin coating Aqueous coating UV resistant coating Urethane coating Acrylic coating Lacquer coating Epoxy coating Heat insulation coating Heat-resistant coating |
Surface treatment | Heat treatment | Quenching Vacuum quenching |
Surface treatment | Other surface treatment | Spattering Coating Teflon coating Buffing Shot blast Sound blast Etching (surface treatment) |
Assembly/Inspection | Assembly | Auto parts assembly |
Assembly/Inspection | Repair | Auto parts repair |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Other parts | Model manufacturing Sign board manufacturing |
