Most recent update: 2022-06-28
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Automatic lathe( Development and production of prototype/Small-scale production / Machining ) |
Company name |
株式会社 井上精密 (Inoueseimitsu) |
Website URL | http://inoue-seimitu.com |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 12 |
Annual sales | Unregister | EMIDAS Member Number | 45833 |
Type of manufacturing | Office automation equipment / Electronic parts / Office appliances |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Deep hole drilling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Molybdenum alloy Automatic lathe Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Form grinding Centerless grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Zinc (barrel) Nickel (rack) Chromium (rack) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Tin-zinc alloy plating (rack) Trivalent Chromate (barrel plating) Iron Brass Aluminum Stainless steel Other anti-rust treatments Hard chromium (rack) Degreasing Black oxide finish Hot-dip galvanizing (small-size Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Vacuum annealing Austempering High frequency quenching Solution heat treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Precision equipment assembly |
Parts manufacturing | Machinery part | Optical parts manufacturing |
Parts manufacturing | Electrical part | Connector manufacturing Other electrical part manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Nut manufacturing Screw manufacturing |
