Most recent update: 2023-08-30
Company name |
昭和スプリング 株式会社 (Shouwasupurinngu) |
Website URL | http://www.showasp.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 60 |
Annual sales | Unregister | EMIDAS Member Number | 45815 |
Type of manufacturing | Transportation equipment / Construction material / Lighting equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing General-purpose jig designing |
Designing | Electrical planning | Electrical machinery and apparatus designing Other electronic part designing |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Deburring Mirror surface machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Sash molding die |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Wire spring die Leaf spring die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Assembly/Inspection | Assembly | Office equipment assembly Auto parts assembly Construction component assembly |
Assembly/Inspection | Inspection | Metal press Spring |
Parts manufacturing | Spring | Thin leaf spring Compression coil spring Tensil coil spring Torsion spring Leaf spring Shaped spring Carbon steel Stainless steel Copper alloy |
