Progressive die( Die manufacturing / Press die ) |
Progressive press (35 - 80 t)( Mass production / Metal press ) |
Single press (below 80 t)( Mass production / Metal press ) |
General metal press die( Designing / Mold designing ) |
Electric discharge machining( Development and production of prototype/Small-scale production / Electrical discharge machine ) |
Manufacturing( Die manufacturing / Press die ) |
Designing( Die manufacturing / Press die ) |
Micro hole machining( Development and production of prototype/Small-scale production / Electrical discharge machine ) |
Stainless steel( Mass production / Metal press ) |
Thickness: below 0.2 mm( Mass production / Metal press ) |
Company name | Hanno Precision .Co.,Ltd | Website URL | |
Street address |
Hanno City Saitama Japan
[See map] |
Person in charge | 中山久喜 |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 10,000,000 JPY | Employees | 24 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 43707 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Medical equipment | ||
Main 3 products |
PR message
Mold manufacturing, press processing, and assembly of communication equipment, speed reducers, crystal transmitter, medical equipment, watch parts, semiconductors, electronic parts, and all other precision metal parts. To make fine parts of 80 ton press or less, we are good at progressive die and confident in technology !!
Most recent update:2022-08-04
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel Aluminum alloy Nickel alloy Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | NC milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Deburring |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Drawing die Bending die Blanking die Forming die Shaving die Progressive die Single press die Below 60 t |
Mass production | Metal press | Drawing Bending Blanking Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Single press (below 80 t) Progressive press (35 - 80 t) |
Assembly/Inspection | Assembly | Precision equipment assembly |
Parts manufacturing | Machinery part | Optical parts manufacturing |
Parts manufacturing | Electrical part | Connector manufacturing Other electrical part manufacturing |
Parts manufacturing | Spring | Thin leaf spring Terminal spring |
