RCF FREE:Bulk Form of Alkaline Earth Silicate (AES) Wool
ISOWOOL BSSR BULK is an AES (Alkaline Earth Silicate) Wool product featuring:
* Extreme high-temperature stability
* Low thermal conductivity
* Lightweight
* Low heat storage
* Excellent chemical stability
* High thermal shock resistance
ISOWOOL BSSR BULK can be used directly as a high-temperature filler and packing, as well as a base material in the manufacture of the BSF product line.
It is ideally suited for conversion to BOARD and VACUUM FORMED SHAPE.
As for filler and packing usage the available packing density are 60 ~ 250kg/m3 in general.
Size of Blank Material
Quantity per carton : 10kg
Carton Size : 470X470X620mm
Quantity per carton : 15kg
Carton Size : 550X550X600mm
Applications :
1. Expansion joint filler for brick wall
2. Back-Up insulation for the industrial furnaces
3. Burner tile and Peep hole packing
4. Gap filler on repairing work of the industry furnace wall.
5. Feedstock for production of ceramic fiber products such as boards, felts, papers and vacuum formed shapers
6. Feedstock for production of the various fiber reinforced composite, machinable ceramics, paints etc.
Company name | YUTAKA CORPORATION | EMIDAS Member Number | 35953 |
Kobe City Hyogo Japan |
Telephone number | +81-78-995-3393 | Fax number | +81-78-995-3390 |
Employees | 10,000,000 JPY | Annual sales | 555,000,000 JPY |
Employees | 14 | Person in charge | Masahiro Toyoda |
Type of manufacturing | Industrial machinery / Electronic parts / Transportation equipment |
