Most recent update: 2024-04-12
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社 林製作所 (Hayashiseisakusho) |
Website URL | https://hayashi-factory.sakura.ne.jp |
Street address |
Kyoto Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 9 |
Annual sales | Unregister | EMIDAS Member Number | 35951 |
Type of manufacturing | Jigs and tools / Industrial machinery / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Thread-cutting Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Machining (resin) Keyway milling Milling (resin) Air chuck equipment Lathe machining (resin) Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding Internal grinding Rotary grinding |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Wire machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Air chuck equipment Turning machining(plastic) Ultra-thin High precision High strength |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Copper (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Zinc (rack) Alumite (anode oxidation) Electroless nickel (barrel) Electroless nickel (rack) Iron Copper Brass Aluminum Stainless steel Black oxide finish Colored alumite Hard alumite Black nickel |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Printing and others | NC engraving |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Salt bath quenching Vacuum quenching Austempering High frequency quenching Flame quenching Solution heat treatment Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Teflon coating Shot blast Glass beads blast |
Assembly/Inspection | Assembly | Precision equipment assembly |
Assembly/Inspection | Inspection | Measuring |
