NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Automatic lathe( Development and production of prototype/Small-scale production / Machining ) |
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Stainless steel( Development and production of prototype/Small-scale production / Machining ) |
Screw manufacturing( Parts manufacturing / Bolt/Screw/Nut ) |
Iron( Development and production of prototype/Small-scale production / Machining ) |
Company name |
株式会社 中井精密 (Nakaiseimitsu) |
Website URL | http://www.nakaiseimitsu.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 4 |
Annual sales | Unregister | EMIDAS Member Number | 35950 |
Type of manufacturing | Telecommunication equipment / Transportation equipment / Electronic parts |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Tapping Gear hobber Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Nickel alloy Molybdenum alloy Keyway milling Automatic lathe Bench lathe machining Lathe machining (resin) |
Development and production of prototype/Small-scale production | NC machining | NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Small-size prototype manufacturing |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Bearing manufacturing Connection parts manufacturing Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Electrical part | Connector manufacturing Other electrical part manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
