Most recent update: 2017-09-29
Company name |
株式会社 安秀工業 (Annshuukougyou) |
Website URL | http://www.ansyu.co.jp |
Street address |
Ibaraki Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 90 |
Annual sales | 1,400,000,000 JPY | EMIDAS Member Number | 35759 |
Type of manufacturing | Office automation equipment / Telecommunication equipment / Office appliances |
Large | Medium | Small |
Designing | Mold designing | Drawing metal press die designing General metal press die NC data creation (press) |
Development and production of prototype/Small-scale production | Machining | Spinning Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Single press die Press robot die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Spring mold | Manufacturing Spring die part processing Leaf spring die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Assembly | Office equipment assembly |
Assembly/Inspection | Inspection | Metal press Measuring |
Parts manufacturing | Spring | Thin leaf spring Leaf spring |
