Most recent update: 2022-01-24
Chassis prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name |
株式会社 内外 (Naigai) |
Website URL | https://www.kknaigai.co.jp/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 37 |
Annual sales | Unregister | EMIDAS Member Number | 34297 |
Type of manufacturing | Home electrical appliances / Transportation equipment / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Injection molding die General metal press die Extrusion molding die designing 3D modeling (plastic) NC data creation (press) NC data creation (plastic) |
Designing | Product and part designing | Office equipment designing Wooden product designing Model designing Medical equipment designing External design |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) Automatic lathe Milling (resin) Lathe machining (resin) Casting Handles microfabrication Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Pipe bending Coating Hair line machining Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) CO2 laser machining UV laser machining Microfabrication (laser machining ) Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Ceramic Acrylic PI (polyimide) Other resins |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding Jig grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Photoforming Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Vacuum injection molding Model manufacturing Porous plastic prototype |
Die manufacturing | Press die | Part processing NC data creation 3D modeling Drawing die Bending die Blanking die Single press die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining NC data creation 3D modeling Injection molding die Vacuum/Air pressure molding die Extrusion molding die Insert molding die Outsert molding die Below 60 t 60 - 300 t Thermoset resin die Light guide plate molding die manufacturing Injection molding die for microfabrication (5 mm or smaller) |
Die manufacturing | Rubber mold | Rubber mold part processing Part processing 3D modeling Compression molding die Home electrical appliances Medical |
Die manufacturing | Casting die | NC data creation 3D modeling Die-casting die Lost-wax casting die Sand casting die Wooden model |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Combined press-joining Single press (below 80 t) Single press (200 - 500 t) |
Mass production | Plastic | Vacuum molding Extrusion molding Insert molding Outsert molding Air pressure molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic Fluororesin Thermoset resin FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) Elastomer Below 60 t 60 - 300 t 000 t Injection molding EP (epoxy) Handles small-scale production Special shape extrusion molding |
Mass production | Rubber | Rubber product prototype manufacturing Compression molding Blanking Silicon rubber Urethane rubber Packing-related products Home electrical appliances Mobile phones Light electrical/earthing rubber Medical Press stamping |
Mass production | Casting | Lost-wax Sand casting |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Copper (barrel) Chromium (barrel) Black chromium (barrel) Chromate (general) Nickel (rack) Tin (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Plastic Other anti-rust treatments Titanium Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) |
Surface treatment | Coating | Air-spray coating Resin coating UV resistant coating Melamine coating Urethane coating Acrylic coating Lacquer coating Epoxy coating Metal coating |
Surface treatment | Printing and others | NC engraving Engraving Silk screen printing Silk (handles curved surface) Pad printing Hot stamping (gold embossing) |
Surface treatment | Other surface treatment | Vacuum deposition Spattering Coating Teflon coating Buffing Shot blast Sound blast Glass beads blast Etching (surface treatment) Frame spraying Arc spray Plasma spray |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Compression coil spring Tensil coil spring Leaf spring Battery spring Formed wire spring Volute spring Torsion spring Carbon steel Stainless steel Copper alloy Diameter Diameter Diameter |
Parts manufacturing | Other parts | Model manufacturing |
Product manufacturing | Production property | Electrical machinery and apparatus manufacturing Information equipment manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Telecommunication equipment manufacturing |
