Most recent update: 2010-03-12
Company name |
株式会社 北斗 (Hokuto) |
Website URL | http://www.hokuto-g.co.jp/ |
Street address |
Gunma Japan
[See map] |
Person in charge | - |
Capital | 70,000,000 JPY | Employees | 50 |
Annual sales | 1,200,000,000 JPY | EMIDAS Member Number | 34285 |
Type of manufacturing | Office automation equipment / Office appliances / Home electrical appliances |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Drawing metal press die designing Transfer press die designing General metal press die |
Designing | Product and part designing | Office equipment designing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing Corner shearing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Drawing die Bending die Blanking die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t Over 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Beryllium copper Transfer press (200 - 500 t) Press robot (80 -200 t) Press robot (200 - 500 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Surface treatment | Plating/Chemical conversion treatment | Zinc (barrel) Chromate (general) Nickel (rack) Gold/Silver plating Zinc (rack) Alumite (anode oxidation) Electroless nickel (rack) Iron Aluminum Stainless steel Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) |
Surface treatment | Coating | Powder coating Resin coating Electrodeposition coating Electrostatic coating Melamine coating Urethane coating Acrylic coating Epoxy coating Metal coating Fluorine coating |
Surface treatment | Printing and others | Silk screen printing |
Surface treatment | Heat treatment | Normalizing Annealing Carburized quenching |
Assembly/Inspection | Assembly | Office equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press |
