Most recent update: 2023-07-22
Blade manufacturing ( Parts manufacturing / Other parts ) |
Company name |
皆川農器製造 株式会社 (Minagawanoukiseizou) |
Website URL | https://www.minagawa-nouki.co.jp/ |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 36,000,000 JPY | Employees | 65 |
Annual sales | Unregister | EMIDAS Member Number | 34241 |
Type of manufacturing | Industrial machinery / Transportation equipment / Office appliances |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Spinning Iron Stainless steel |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Brazing |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Iron Stainless steel Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) |
Mass production | Forging | Hot forging Press forging 500 g - 5 kg |
Surface treatment | Plating/Chemical conversion treatment | Chromium (barrel) Zinc (barrel) Chromate (general) Chromium (rack) Black chromium (rack) Parkerizing (phosphate film) Electroless nickel (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Black oxide finish |
Surface treatment | Coating | Electrostatic coating |
Surface treatment | Polishing/Lapping | Blade polishing |
Surface treatment | Heat treatment | Annealing Stress relief annealing (SR treatment) Quenching Vacuum quenching High frequency quenching Solution heat treatment Carburized quenching Nitridation |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Spraying Shot blast |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Parts manufacturing | Machinery part | Shaft and roller manufacturing |
Parts manufacturing | Spring | Thin leaf spring Leaf spring Carbon steel |
Parts manufacturing | Other parts | Blade manufacturing |
