Most recent update: 2023-07-13
Company name |
株式会社 鈴民精密工業所 (Suzutamiseimitsukougyousho) |
Website URL | http://www.suzutami.com |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 95,000,000 JPY | Employees | 108 |
Annual sales | 2,000,000,000 JPY | EMIDAS Member Number | 3052 |
Type of manufacturing | Measuring machinery / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Cylindrical grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding Arc welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Die manufacturing | Press die | Drawing die Bending die Blanking die Single press die |
Die manufacturing | Forging die | Cold forging die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Copper Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Forging | Hot forging Cold forging Press forging Drop hammer |
Surface treatment | Polishing/Lapping | Chemical polishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast |
