Most recent update: 2018-01-28
Turret punch press processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name |
株式会社 シオノテックス (Shionotekkusu) |
Website URL | http://www.shionotex.jp/ |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 16 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 29108 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Measuring machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Spinning Machining/Handles small-scale production (order from 1 piece) High rigid material Copper alloy Nickel alloy Bench lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Laser and turret punch press processing Water jet cutter machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Welding |
Die manufacturing | Press die | Manufacturing Die set machining Drawing die Bending die Blanking die Shaving die Progressive die Single press die Below 60 t Compound die |
Mass production | Metal press | Bending Blanking Thickness Single press (below 80 t) Progressive press (35 - 80 t) |
Mass production | Mechanical processing | NC turning machining Complex turning machining Electrical discharge machining Automatic screw machining |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Trivalent Chromate (barrel plating) |
