Most recent update: 2024-02-28
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
有限会社 松澤精機 (Matsuzawaseiki) |
Website URL | http://www.matsuzawaseiki.com/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 4 |
Annual sales | Unregister | EMIDAS Member Number | 24936 |
Type of manufacturing | Machine tools / Measuring machinery / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Molybdenum alloy Machining (resin) Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Profile grinding Internal grinding Thread grinding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Small-size prototype manufacturing Fused Deposition Molding (FDM) |
Mass production | Plastic | PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) LCP (liquid crystal polymer) Fluororesin Thermoset resin FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) Elastomer Below 60 t 60 - 300 t 000 t PES (polyethersulfone) FRP molding (hand lay-up/spray lay-up) EP (epoxy) |
Mass production | Rubber | Rubber product prototype manufacturing Silicon rubber Urethane rubber Butyl rubber NBR SBR CR EPT Fluoro-rubber Acrylic rubber Packing-related products binoculars and optical products |
Assembly/Inspection | Assembly | Precision equipment assembly |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
