Most recent update: 2023-04-13
Company name |
協業組合 菊水フォージング (Kyougyoukumiaikikusuifo-jinngu) |
Website URL | http://www.kikusui.org/ |
Street address |
Tottori Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 63 |
Annual sales | 1,500,000,000 JPY | EMIDAS Member Number | 22522 |
Type of manufacturing | Industrial machinery / Transportation equipment / Leisure goods |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Planer machining Plano miller machining Deep hole drilling Profile milling Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Boring milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Cylindrical grinding Jig boring |
Die manufacturing | Forging die | Designing Manufacturing Forging die part processing NC data creation Hot forging die Press forging die |
Mass production | Forging | Hot forging Press forging Drop hammer Forging roll Iron Aluminum Brass Others Below 500 g 500 g - 5 kg Over 5 kg |
Surface treatment | Printing and others | Engraving |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Salt bath quenching Vacuum quenching Austempering High frequency quenching Solution heat treatment Sub-zero treatment Carburized quenching Nitridation Gas nitrocarburizing |
