Most recent update: 2024-01-11
Company name |
有限会社 新光 (Shinnkou) |
Website URL | |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 10 |
Annual sales | Unregister | EMIDAS Member Number | 22512 |
Type of manufacturing | Measuring machinery / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Precision sheet metal machining Chassis manufacturing Deburring Mirror surface machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Drawing die Bending die Blanking die Single press die Below 60 t |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Single press (below 80 t) |
Surface treatment | Coating | Air-spray coating Powder coating |
Parts manufacturing | Spring | Thin leaf spring Terminal spring |
