Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Punching( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name | NISINO SEIKI Co., Ltd. | Website URL | http://www.nisinoseiki.com/ |
Street address |
HItatinaka-shi Ibaraki Japan
[See map] |
Person in charge | Nobuhiro Nishino |
Telephone number | +81-29-265-9595 | Fax number | +81-29-265-9090 |
Capital | 10,000,000 JPY | Employees | 80 |
Annual sales | 1,000,000,000 JPY | EMIDAS Member Number | 22469 |
Type of manufacturing | Audio-video equipment / Electronic parts / Transportation equipment | ||
Main 3 products |
Primary clients |
PR message
We Can Respond To A Wide Variety In Small Quantity.
We Will Deliver Quickly.
1. We are the best at processing with size of a rice grain to A3.
2. We have an ability to handle 2D/3D data.
3. Precision sheet metal, test pressing, MAG/MIG welding, machining center processing, combined lathe processing, laser punching.
4. We will take orders from single unit.
5. We can do a same-day estimate.
6. We process mainly steel, aluminum, stainless, copper, difficult-to-machine materials, etc
7. We can do 3D measuring, ultrasonic cleaning.
8. Utilizing our cooperative companies, we can deliver products with surface treatments, heat treatments, plating, etc.
From Single Piece Order With Short Lead Time For “Quick-Sheet Metal”
http://speed-bankin.com/
A Web-site specially made to respond for needs of quick-sheet metal.
Process-able size: from a dice to volleyball.
①Up to max of 4 bending.
②Angel must be within 180.
③In-stock materials (including thickness). See below.
*For simply can-be-made precision sheet metal products, we can deliver within 4 days.
*By using “Find Out an Estimate By Yourself,” you can find out an estimated price by yourself.
*We take short lead time orders from a peace. We use the TRUMPF laser puncher for cutting, tap processing, and a bender for bending, in addition to, quality guarantee using 3D measure.
*We will gladly respond to urgent trial product manufacturing.
*We also can produce high-end precision sheet metal and high-end trial parts with press.
*We can process stainless metal for spring and phosphor bronze from thickness of 0.1mm.
*Blanking is done by wire cutting, edging, and laser cutting.
*Must be COD till 3rd order.
Most recent update:2025-02-07
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Nickel alloy Machining (resin) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Cutting Laser and turret punch press processing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
