Most recent update: 2008-10-17
Company name |
株式会社 渡辺製作所 (Watanabeseisakusho) |
Website URL | http://www.kk-watanabe.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 120 |
Annual sales | 1,400,000,000 JPY | EMIDAS Member Number | 22328 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Measuring machinery |
Large | Medium | Small |
Designing | Industrial equipment designing | Industrial machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Planer machining Profile milling Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Nickel alloy Automatic lathe Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | NC milling |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Copper (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Aldine treatment (aluminum chromate) Electroless nickel (barrel) Trivalent Chromate (barrel plating) Iron Aluminum Unichromate (white) |
Surface treatment | Coating | Air-spray coating Powder coating Electrodeposition coating Electrostatic coating Melamine coating Urethane coating Lacquer coating Epoxy coating Metal coating |
Surface treatment | Printing and others | NC engraving Engraving Printing Silk screen printing |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Monitoring device manufacturing Environmental equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing |
