Thickness: 3.2 - 9.0 mm( Mass production / Metal press ) |
Progressive die( Die manufacturing / Press die ) |
Single press die( Die manufacturing / Press die ) |
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Single press (80 - 200 t)( Mass production / Metal press ) |
Iron( Mass production / Metal press ) |
Stainless steel( Mass production / Metal press ) |
Company name | ARIKAWA WORKS INC. | Website URL | |
Street address |
Kanazawa City Ishikawa Japan
[See map] |
Person in charge | inaho kubota |
Telephone number | +81-76-263-6225 | Fax number | +81-76-262-8723 |
Capital | 20,000,000 JPY | Employees | 30 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 22317 |
Type of manufacturing | Machine tools / Industrial machinery / Electronic parts | ||
Main 3 products |
PR message
Our company designs and manufactures molds and processes pressed products. We manufacture all kinds of industrial machine parts such as textile machine parts, electronic parts manufacturing machine parts, machine tool parts, etc.
Based on the mold technology that we have cultivated up to now, such as [100% shear surface with normal press] and [buffless processing by R pressing], we will propose a method conversion that will benefit our customers. We aim to be a company that pleases customers by adding technological value to the press.
Most recent update:2023-09-09
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Iron Stainless steel |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Fine blanking die Shaving die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Fine blanking Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Stainless steel material for spring Thickness Thickness Thickness Thickness Diameter Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
